Suggested rear shock sag measurements
I've recently bought a YZ450F shock spring for my YZ250 which should be perfect for me accoarding to mx-tech.com website but im having trouble finding correct static sag, can anyone please tell me as a rule what static sag should be and also race sag and i will try to set it all up again! i've tried trolling the suspension forum but theres so many numbers on there, and i can't see it in the manual? Cheers
Nearly,
Once you set your race sag, 100-105mm then you can check your static sag.
Should be 25-30mm
Good luck
