xr600 bottom fork screw procedure...
Not the axle, but the 4 threaded "shafts" which screw into the fork leg...Do you place the respective bolts fully screwed down so that you can use a socket or wrench and then screw the shorter side into the fork leg? Do you use blue locktite on it or some other anchoring liquid?
Thanks:ride:
I would use some locktite and bind two nuts together to drive the shorter side in.
