Start only with great kick...
So, still have trouble with my 450R 2005
When I start it on the stand, or when I have a wall or something for keep the balance. Usually I need between 4-8 great kick for start it. But when I stall in the trail, it's impossible to start alone. I need someone holding the bike, and sometimes I can kick more than 20 times before it start. I noticed today some small backfire when I kick it. But when is started, everything run great. Also, the choke knob never stay on. It always disengage alone.
I reajust the valves
Check timing
Compression...70 psi after 6 kick (engine cold)
Inspect sparkplug and spark
Try the pilot screw between 1 turn to 3.5 turn out
No leak on the intake or carb boot
Brand new exhaust gasket, and nicely torque
The carb was completely dissembled 3 hours before the end of the seasons
Try to start with the hotstart
Try to twist the throtle one time
Last winter I replace
ICM
Stator
Coils
Sparkplug
Crankshaft
Piston (12.5:1)
All bearing
JD carb jetting kit
JD leak jet kit
AP mod
Wiring
So, I need some idea, I don't know what I should do again
What setting did you use to adjust the decompressor?
I use a feeler in the valve and then set the decompressor to .014"
You cant do it correctly by shoving .025" into the decompressor after adjusting the valve. Not sure why, but it doesnt work out.
Mess with the decompressor lash a little bit. Its more finicky than you'd think.
Its just a guess though.
I check it and I have .014
But what you wanted to say with this...
I not so good in english, Usually I understand everything, but for this part I need more explanation
You need to put a feeler in the exhaust valve whichever is correct then check the decompression lash with another feeler gauge. Also what jets exactly does it have. There is NO universal kit. Has it always been hard to start or did you do something? Check stator and coil resistance.
I have the JD jetting kit
Pilot 42
Main 185
Forget the needle clip...
The stator is brand new, the old one make it impossible to start, and after some time the engine stalled . But now one is started, the engine run great
My '02 450 has a 175 Main jet, and even that is probably a little too rich, let a lone a 185.
To me, it sounds like you have some carb problems. I'd tear it all down and give it a good cleaning. My '02 CRF450 will start first kick hot or cold 90% of the time.
I agree with you Lead Head, my '02 starts 99% of the time first kick cold.
:smirk::ride:
The JD jet kit uses a different needle that is way way fatter at the very end of it so the jet looks richer than it really is.
If you look at the JD needles next to the OEM needle, the little cone at the end of the JD is almost twice as large.
When you set the decompressor clearance, you need to use two feelers. Set the exhaust valve clearance first, then set the decompressor clearance with the .011 feeler still in the exhaust valve rocker.
Verify youve got spark too.
Kicking it with the plug out easily should get you even a tiny red spark which is enough to start the bike.
Remember the triangle.
Spark
Compression
Fuel.
gotta have them all...
This weekend I've got more info, I didn't have time for dissembly the carb but...
When I drop the bike on the side, a LOT of fuel coming out the carb.
Also the choke knob didn't stay engaged when I used it, something suck it for disengaged it. (When I start or running, when engine off, this one stay on)
So this weekend, when I fall or stop it, I always close the fuel pickup. Only one time I had a lot difficult to start. Other time, start between 2 and 5 kick
I think I have a carb float trouble, I gonna dissembly it the next rainny day
See if accelerator pump diaphragm is worn or broken apart, Mine was and throttle flick wouldn't allow the squirt of gas
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
