Watch for your stage two clearance..650R
I decided to fresh'n up the ol' 01 650R today. It's been trouble free for years,no oil burning etc.etc.Stock piston.
Pulled it apart and found that the ex valves had been kissing the piston lately:eek:
I thought i'd heard a exhaust leak last time i'd run it,but now i'm thinking the cam chain is worn enough so the valves will touch the piston.
I think i got lucky...
Yup.........you are lucky.....after repeatedly hitting the piston they like to fly off and stick into the piston....which really screws up good weekends:bonk:
:smirk:
B
I really was surprised how small the chain is. I'm replacing everything except the rockers. I might even take a step 'backwards' to a stage one cam,now this bike is now not needed for full speed trail abuse.
isn,t there a hop up cam chain still available from honda?i think it was part of the factory hop up kit.that kit is now not available but i think you can get the chain seperatly
whats a hop up?
I think stage two is good if your going to mod the piston, otherwise not worth the trouble.
Ive read people advancing the cam, so that means they would move it one tooth advance, but that may be too much! i dont know and to me isnt the proper way to go.
Thats why i chose the ST1 cam, i didnt want this to happen in woop woop town.
I like the stock cam, and how do you know you got lucky?????
I would replace the valves.
I was lucky because it didn't break a valve off or strand me somewhere with a bent valve. :thumbsup:Like i said before..everthing is getting replaced,,valves,valve springs,chain,cam.etc.
I'm not sure how many miles on this cam,i put it in about 4 years ago? I do mainly trail rides with the exception of a few long dual sport rides. I'd guess 2500 miles? And the chain is stock from 01.
I'd like to put in the HRC chain,but i think it will have to be put in with their sprockets too. Still looking into that...
*nevermind..i just found the prices on a chain up-grade,,close to 500.bucks!!
I still have a stock cam and have swapped it back in once for trouble shooting "stalling issues" But in comparrison,,it's WAY too slow.
Edited by scalejockey
  • Similar Content
    • By TheLastByte
      Contemplating picking up a BRP in the near future and looking for some perspective.The current owner claims that the bike has about six hundred hours on it, but there's no way for me to confirm as the odo's not accurate.
      I know brp's have a reputation for running forever on stock top ends, but they must eventually have an expiration date. What should I look for on a high mileage bike like this to make sure I'm not setting myself up for disappointment? Also, What are some non engine/transmission related issues I should look for?
    • By TanSnowman51
      Guys,
      Have been riding my 650L for over a year and a half and have been loving every second! In August I moved back to Reno after finishing up my masters at Arizona State. I have been spending most of my time riding around verdi to stampede and the Dog Valley road area. Always looking for riding buddies.
      Was curious what everyone was doing as far as Daves mods or jet kit for the upper elevations 4,000 to 8,000 feet?
      FMF Q4 exhaust, smog delete done so far!
      Thanks!
    • By Alexandre Askmo
      Hey dear folk!
      I need your help.
      A bit of background info, I’m a complete noob when it comes to holding a wrench and doing anything more than filling up the bike. I have however had an interest for as long as I’ve had a bike to make it mine, and that’s why I’m writing to you now. I just bought a donor bike, a Honda NX650 which a friend of mine is helping me fix up and then modify to my liking (I’m hoping to end up with a gorgeous scrambler in about 9 months).
      We found a hairline scratch in the cylinder and need to bore it. This leads me to my question.
      Should I get a 1st overbore performance piston or keep the compression ratio as is? If so is there anything in particular I will need to modify to tolerate the high compression piston?
      If I do get the performance piston, should I also get a new carburetor, hot cam, and new exhausts? I am planning on new exhausts anyway (2-1 from an XRL) and I’m planning on removing the airbox and getting a K/N pod air filter.
      Again, keep in mind I know nothing, my friend has however fixed up a bunch of XRLs and cars but never really used performance parts. Help me out with the decision please, I would also like to keep the whole build to a reasonable cost (I know this is a very relative number).
      I should also add that I want to keep the DNA of the bike, for example keeping the fuel tank instead of switching to a smaller rounder one as one usually sees in most custom builds. The aim of the whole build is to have an insanely fun bike to ride, both in the city and off-road, as well as giving it a bunch of my personality 😊
      Thanks a lot for any help!
      Best,
      Alex
    • By MrCitizen
      I've been rebuilding/restoring an XR650R for some years now (after toasting the motor in 2013). Sent the motor off to be rebuilt, had a local shop rebuild my forks and shock, and took care of most everything else myself.
      As of a couple months ago I had almost everything assembled and ready to run.
      As a final check before adding fluids to the bike, I decided to stick my boroscope into cylinder and take a look. The results were concerning.
      These boroscope pics looked so gnarly that I pulled the head off the motor to get a more thorough look.
      To say that I'm concerned is an understatement. I have pics of the motor internals pre-rebuild, and can confirm that this is definitely a new piston and replated cylinder. I also have all the old parts from the motor, so it does have a new cam, connecting rod, valves, and basically everything else I expected to have replaced.
      The builder "ran the motor briefly to confirm everything ran alright" and then shipped it back to me. I reached out to him with these pics and he said,
      The piston looks like this because he had it machined from 12:1 to 11:1 compression. The streaks on the cylinder wall are normal for one that isn't broken in yet. Regarding the valve impacts in the piston head: "My concern is that something may have passed through the cylinder. How does it run?" I've never run this motor. I can feel these streaks in the cylinder wall with my fingernail. Did he re-use a piston from some other motor?
      Is this dude jerking my chain or is this motor fine to run?
      He's a fairly well-known builder in the XR community and was recommended to me by guys in the (now-gone) XR650R forum.
    • By Jonas Reppe
      I got my XR600r dirt bike giving me a carb issue that I just can not get worked out. It starts first kick and idles well, throttle cracks off nice and crisp when you whack it, but if you ease into the throttle to just above idle it's a spit and sputter pile of shit! Lol. I can turn the idle speed adjustment up to a fast idle and it starts spitting and studdering just the same. Done a lot of research and it points to the pilot circuit. I put a rebuild kit in it and have taken it apart and cleaned it seriously 12 times now. I'm at the point of looking for a different carb body to try. They're about $100 though. A new keihn carb is $250 on eBay. Any thoughts? That pilot adjust screw doesn't seem to adjust anything until it's fully seated or falling out. It has ran ok in that idle to 1/4 throttle circuit before but it don't now. The last 6 removal/cleanings haven't made any changes, previous ones did improve the throttle snap when you whack it.
      The main needle clip is on the middle groove.
      I checked for air leak with some starting fluid when it was idling and seen no change to the way it ran, indicating no leaks.
      Bike has stock jet sizes, foam filter, stock exhaust. 1,830' elevation here in South Dakota.
      I'm baffled..
