Cutting plastics
I trace a line with a marker or razor then use a drumel tool to cut it. It makes it quick and easy. Then I usually sand it to smoth it out a little. Good luck!
+1 on the dremel...a cutting wheel on the dremel worked great for me. My dremel is a variable speed model, and I found that helped quite a bit...
Jay.
CaveMike chew. Chew dead animal, chew garbage, chew plastic.
