FCR 40 jetting
i have an FCR 40 off a honda dirtbike, i know its not the right one but i am going to make it work, where should i be at for jetting as a starting point? i know i am going to have figure out the final setup for myself but again i just need a starting point so i dont burn this sucker down thanks
100 slow air jet
200 main air jet
EMN needle, clip 3
45 pilot
155 main jet
Wire AP linkage
Block Leak jet if equipped
No damage can occur if you are too lean with a 4S. If could be so lean as to barely run and it would be ok.
ok thanks for the info, on quick question, what do you mean by wire the AP linkage?, i see the acclerator pump linkage but what am i wireing ?
This is not entirely true, in most cases a lean condition will cause poor running and a obvious problem that needs attention.
But in the the case of a too lean Main Jet, it can cause catastrophic failure during sustained WOT, ask any desert racer.
