pinging and fuel
After the rebuild I hear this metalic sound from the engine at 1/2 throttle,it comes even if just running on open road(no load).First thought was power valve rattling as it seems to happen when the valve would be opening.all this is happening when I have a slight gurgle in the throttle response like its running rich in that spot.It seems to go away if I go full throttle and isn't there going slower,my fear is that it pinging and will ruin my engine.What I was wondering is if trying octane boost would be effective in eliminating pinging or is it a waste of money.I would try it and if it goes away then I would repair whats causing it,I'm thinking the head needs squish band adjusted.I had the head opened up to accomodate a 68.5mm piston and the machine shop ran the cutter over the squish area,didn't look like much,just to clean it up but he might have raised the squish too much.
the additive is crap, irrc the best stuff raises the octane rating 0.3 ron (negligable). can you get some aircraft fuel? maybe just a little race fuel from a friend or maybe a shop around you has an open can theyll give $5 worth or something? having said all that, pinging ussually happens under a load, not cruising like you describe. maybe piston slap? are you sure the bore is the right size and the piston is as well? or it could just be the PV
bore is new and piston is new,bought together and I checked clearance before installed,to me it sounded like power valve too as when its happening if I give her more throttle it goes away.Today I checked the timing and found I had her a tad advanced but not by much,I adjusted her just slightly retard and will give her a try today.
was going to mention that too. just because the bore and piston are new doesnt mean there wasnt a mistake made, but you measured, so it should be good there.
Timing retarded got rid of the ping but killed my bottom end,although mid to high was awesome.Put the timing back to stock which is still slightly retard from before but haven't tried it yet.Think I would rather live with the ping and keep the bottem end,or maybe its time to ditch the pc pipe and get a gnarly.Guess I just got to find a happy medium between the 2.Trail riding with the timing retarded is great but sand pit riding it sucks.
Trust me, Sacrifice the bottom end power over ping, You do not want that thing pinging and detonating. For the price it'll cost you for a new top end you could pull your cylinder off right now and send it to eric gore and the head and have him set it up for whatever pump you want with all the porting in the world for bottom end cheaper.
fiddled with the timing some more and got her a small amount advanced and put the 48pilot back in and its very close to what I had before but now there is no pinging.With the timing retarded she had very smooth power but the low end suffered,for open trails with little tight stuff it would have been awesome.If there was only a way to hook a thumb screw to the stator plate so it was adjustable like the idle screw,that would be awesome.Tight trails advance it and open areas retard it with the twist of a screw.Hmmm may have to patent something there.
