hard to shift into 5th, 2011
I just got a new 2011, it has about 5 hrs, no false neutrals yet, but it won't shift under load into 5th gear, in the air is fine but under hard acceleration I have to back down and use the clutch to shift. On the other gears is fine. Has anyone had this problem.
You should be using the clutch to upshift to any gear. Just a quick stab if you want to keep the power on thats fine. That is hard on a transmission that is already suspect. Bad idea! Keep the RPM's up and power shift. 5th gear is tall so youll want to be on the gas anyways to keep it in the higher rpms or else youll bog and lose time!! Cheers
