controls on 230
Any one have any info on a diff electric start button that takes up less space. I am trying to install a set of cut down bars and bark busters on my sons 230 for haresrambles, Some areas need narrow bars. Also the brake master cylinder hose metal piece hits on the pro taper cross bar mounts and wont lay flat on the bar. Any ideas?
I just used a two wire kill switch. Works fine, takes up a lot less room on the bars and matches the stock kill switch.
My protapers were 800mm wide and cut them down to the second line. I had the same problem and filed a little off the metal piece of the master cylinder and a little off the crossbar where they touched.
Try BTO Sports. I bought a nice kill switch from them that attached to the front break perch. works good for me and is clean.
