manual cam chain tensioner?
just wondering if anyone else here besides me and picapacapopo has made their own MCCT?
last may long weekend I was going to go riding with my stock, 2005 auto cam chain tensioner failed!! I had seen MCCTs online before and they looked like a very simple device..
so I brought the ACCT down to the local dirtbike shop where a good friend worked and explained to him my situation. he agreed that it would be possible to make your own MCCT and we could do it.. but he wouldnt do it on his own bike as he didnt trust it.
so we got a piece of rod the same thread size and pitch as the center hole of the MCCT, adjusted it to length, and threw some nuts, washers and red loctite on it. it was only supposed to be temporary. I seen this friend again after not seeing him for 14 months and his jaw nearly dropped when he seen I was still using our MCCT lol. I understand if this thing ever fails it can/will ruin my engine, and a new proper one is 50$.
so I was wondering. has anyone else here ever made their auto cam chain tensioner into a manual one?
I did the exact same thing you did. I only rode the bike for the weekend that I was waiting on my TT MCCT but I honestly once you look at how the thing works and what it does, the TT part is wildly over engineered with that big ass bolt.
The only concern I had with doing exactly what you did was the thread that they pressed into the original auto unit. I used the OEM pusher part after taking out the guts (spring etc) and put the sleeve and the plunger back on and just used a longer bolt to push the plunger in and set it with a jam nut.
Youre not the first and Ive never heard of anyone building one like that, that had failed.
yup I've built my own for street bikes. I just gut the original use a piece of all thread a couple nuts. Round off the all thread and put the bolts on. Weld one bolt solid on the end of the all thread and your good to go. Havent had one fail yet
I prefer the auto adjuster so when the spring in mine broke I took it apart, cut the broken end of the spring, rebent the spring end and rewound the spring fixing it for no money. it took several trys to rewind that spring though.
that does not sound like a good idea at all.... shorter spring = less tension which is when things go bad!
i remember a while back, tt member kelstr posted instructions on how to turn your ACCT into an MCCT by using a piece of 5/16 copper tubing to jam the thing open to the correct length. you can find it by searching. what ever happened to kelstr? he always had good info about the crf.
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
