cr250 can i change the frame
hi there just woundering if anybody could tell me if a 1996 cr250 engine would go in a aluminuim new frame 2000 onwards thanks.
I'm not sure if it would mount straight in? You would most likely have to do some fab work.
with most engine swaps the answer is yes it will fit just depends how much modding you have to do to make it fit.
thanks for replies im guna buy a frame and see wat i can do cheers
You can make any engine fit, it just depends on how determined you are to do it, and how capable you are with working with metal.
Ask the guys in the actual CR section of the site here, a lot of them have done cross-generational, or at least year to year motor swaps.
I think it is a direct bolt in up to 02
Anything is possible with duct tape!
does anyone now if my forks and swing arm will go on the newer frame too thanks for the help
Depends on what you mean by "go on".
yes the engine will fit forks possible too from looking and parts refrences it says cr 250 eng is the same 92-01
We can only assume that he means using a copious number of zipties.
okay cheers for help only wana change frame cos it looks an old bike
your pipe wont fit, your plastic wont fit, your seat wont fit, your airbox and subframe wont fit, your swingarm and rear shock wont fit, your gas tank wont fit, your radiators wont fit.. am I missing anything?
Wiring harness?
