Little end bush
Does anybody know if you can buy the little end bush seperate from the conrod ? :smirk:
No the brass bush that sits in the little end of the conrod were the piston pin slides into.
You could have it replaced... But the safer/more practical
Bet would be to drop a new crank in it from hot cams.
If your trying to install a new small end rod bushing with the rod on the crank and crank in the case....I'd bet you have more problems then solutions with that plan.
Hey , the rod is not worn but there is some markings on the lower part of the bush , it looks like you could freeze the bush and slide it right into the small end of the conrod.
If the big end and crank bearings are also worn.....
I recently bought a bottom end rebuild kit for $400.
Included hotrods crank/rod assembled, crank main bearings, and full engine gasket/seal kit.
