Does this look like a yamaha wheel?
I have a front and rear wheel I bought off of craigslist. The guy I bought them from said they were off a 03 cr125. Well that was a lie. Ive narrowed it down to they are off a yamaha or a suzuki. Anybody know if the wheels will fit both bikes. I want to sell the but dont know what to advertise them as and I dont want to advertise them as the wrong item.. They have 36 spokes and there are 6 bolt holes for the front and back brake rotor plus they are excels. The rear is 19x1.85 and the front is 21x1.6. I can post pictures if that helps. Thanks guys.
Rear
Here is the front
just changed my rotor and it bolts on just like that with 10 mm bolt heads, its a 04 yz 250, not sure what anything else has
Was that on the front or the rear. On my rear the rotor has 8mm bolt heads.
My rear on both my 05 and 00 have 10mm rear bolts
I think I can make out "5ET00" on the hub and that matches the original hub from my 06 yz 250. That matches up to the hub Yamah used form 2002-present on the yz 125 and 250.
Im sure rolands right i can see the same 5ET00 on my 06 yz250 rear hub, As the rears a 1.85 it would be for 02+ YZ125 and 02-08 YZ250F's, hope this helps!
Ya on the rear wheel it says 5ET00 and then a little after that it is followed by a T-1 The front says 145-FRY But does the yamaha have ridges on the hubs? There are little bridges on hubs on both of these wheels.
Ok I think I figured out what wheels these are from. I matched up the numbers from this website http://***************/YAMAHAYZ125IDENTIFICATION.aspx The rear wheel will fit a 1999-2009 yz125, 2000-2008 yz250f, All yz250, 1999-2000 yz400f, 2001-2002 yz426f, and 2003 to 2008 yz450f.
The front will fit all rm125 and rm250 from 1989-1995.
Thanks everybody for the help. If you want to buy one just PM me.
Wow, I've never noticed that info on their page before!
Good info for bike re-builders:
http://oem-cycleDOTcom/YAMAHAYZ125IDENTIFICATION.aspx
type into address bar to view....
Evidently, TT is blocking anything that has "***************" in it.
