Oil change question
I want to change my oil, and switch to amsoil synthetic.... And I dont know if there is conventional oil in the bike. Would it hurt to just drain as much as possible and refill. Or do I need to flush the engine first? And if so, how???
thanks
If you take out the drain bolt on the bottom left of the engine (TTR-125) and leave it on it's stand so it's tipped all the oil should drain. Once it's stopped dripping put the drain bolt back in and fill it with the oil you want. Make sure that the oil is suitable for 4 stroke, air cooled and wet-clutch though.:smirk:
