rebuild question
93' XR650L
I have the engine back together and want to make sure I have oil flowing correctly.
So far I have cranked engine only and did get oil flowing up the return line. I thought I should get oil flowing also form the oil line from RH crank case to cylinder head cover, I did not? Should I get oil flowing up this line to the cylinder head cover?
Scott
I found the thread on priming finally. I got oil flowing through line with just little extra cranking. I did read that I could have applied air press to head vent tube or to oil tank to get oil pump primed.
Thanks for the site, It helps a lot!!
:smirk:.......
