2000 CR250 headlight
Im lookin into puttin a headlight on this beast. Im makin an order on steahly offroad for this:
http://www.steahlyoffroad.com/honda-cr-250-99-01-lighting-coil.html
(50 watt stator)
this
http://www.steahlyoffroad.com/voltage-regulator-12-volt-ac.html
(12 volt ac voltage regulator)
and then going to rocky mtn for this
http://www.rockymountainatvmc.com/productDetail.do?navType=type&webTypeId=190&navTitle=Dirt+Bike+Parts&webCatId=19&prodFamilyId=24175
(35 watt headlight)
is there anything else ill need, and will this setup work well?
any info will be great!
I thought that the voltage regulator reduced surging
I would guess a 35 watt light is basically only good for too things. Passing dmv inspection(trying to get it plated) Or illuminating a map because its dark and your lost :smirk:
I have a 55watt light on my xr600 with a baja designs rewound stator. and the light isnt good enough for anything other than second gear(crawling home)
