Renthal R3 O-ring chain- fits 09 450?
I just orderd an R3 O-ring chain, but maybe that was a stupid idea because now that ive read some reveiws it seems that for some bikes its too wide and rubs on the cases....
Just wanted to know if anyone tried it on the 09 450?
maybe next time i should do the research first and then the ordering.....:smirk:
It seems to work fine on my 08 KX450, no rubbing as far as I can tell. Not sure if the cases are the same as the 09 though.
Yeah ive seen some pics of the chain on the 08's but couldnt find any on the 09 so thats why im a bit worried....
Has realy nobody tried this chain on an 09?? comon guys....
I put the chain on an 07 kx450 then heard they were wider later on so I took it off to check and it rubed a bit but only just scored the case just a little not enough for me to worry about. I just put it back on and I havent had a problem.
Their are 3 lillte nubs behind couter sahft sprocket you can grind down. did it to my 07.Just put a o-ring on my 10 no problems.
