Oil Leak at Flywheel Nut Cover
Hi Guys,
I am just getting my bike back running after a seizure and have an oil leak from the flywheel nut cover. The oil just seeps out at idle and increases with engine rpm. I have replaced the o-ring and cover, tried two o-rings, and some rtv on the threads with no luck. The magneto cover does not appear to have any cracks. Any ideas are appreciated. I rebuilt the motor with the athena 490cc big bore and am anxious to get out and ride.
Wow. Thats a tough one bro. .:smirk:
Maybe just form a gasket for now. Really don't need to open it till valve adjust. I know it's redneck shade tree but atleast you can start breaking in that piston and rings
Hi Guys,
It looks like there is damage to the case, below the cover, at about 4 o'clock, that might be a crack....
Just curious - what caused the seizure in the first place?
Check this thread.
http://www.thumpertalk.com/forum/showthread.php?t=960189&highlight=engine+seized
Seems I am the only one that has had a catastrophic engine failure w/o a clear explanation. It took me a couple months to piece the engine back together. I tried more RTV around the threads and at the base of the o-ring and it appears to be holding after a short ride yesterday. I have spent so much $ on the engine I guess I will be purchasing a new magneto cover if this does not hold.
Check this thread.
Sounds like a possibly warped cover??? I'd hate to know what a new one would cost but you should be able to find out if it's "true" if you can find a true plane to test it on.
