CRF 80 - piston ring end gap
Can anyone verify the end gap on the piston rings for a 2004 CRF80?
My manual shows "1998-1999" XR 80, then shows "2000 and later" XR/CRF 100 so I want to be sure before I put it back together.
For the 1998-1999 XR 80 it shows:
Top and second ring is 0.006 to 0.018
Oil rings are 0.012 to 0.035
For the 2000 and later XR/CRF100 it shows:
Top and second ring is 0.002 to 0.008
Oil rings are 0.008 to 0.027
Which measurements should I go with?
Also, do you soak the rings in oil or anything before installation?
Anyone?
Where are all the Honda techs/service folks at?
Rule of thumb.....
Piston diameter in MM................................Min. ring end gap
44 to 50____________________________.004inch
50.25 to 68__________________________.007inch
68.10 to 79.35_______________________.010inch
79.35 to 102_________________________.013inch
Also rule of thumb, but...
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Minimum gap
Top ring 0.007"
2nd ring 0.009"
Yes, oil your rings prior to installation; soaking them has no effect that I'm aware of (I've been wrong MANY times before). Also ensure a good coating of oil on all 'contact parts' of the piston; wrist pin, oil lands and ports etc. Take care to ensure none of your ring gaps overlap or are centered over the piston pin area.
