I really do have a 450
450.jpgttt
http://450.jpg
computer keeps acting up and my wife is bitch'n ,so i'll give all the details later , just wanted to show my 2007 1900.00 pile of crap , months after i got it
can only see first pic
Nice looking bike . Awesome price...
the pic doesnt do it justice, 10pix nikon and every pic was washed out or blury, anyway ,i just wanted to show off the bike , it really looked beat when i got it, I really enjoyed building it ,just wish it didnt take so long,working 6 days a week ,i was just doing it here and there ,and it just dragged on seemed like.
new plastic
new graphics
new tires
red gas cap (bling)
new rims and spokes
glass bead hubs
glass bead outer cases
glass bead calipers
red wheel blocks
NEW kill switch
new red radiator hoses
avs levers
pro taper oversize risers
new over size bars
new pro taper grips
new red zeta stem nut (bling)
new red works master cover
new works fuel screw
new boysen ap bowl
new nuts bolts on 90%
new tag front sprocket
new xso chain
new tag rear sprocket
new sprocket bolts
new disc bolts
new water pump cover(fell off the stand and broke)
new bearings front and rear
new fork seals bushings
new brake pads front and rear
tons of time cleaning the frame , and i mean tonssssssss
tons of time striping the swingarm anodize was scratched up
polished the inside cases
fc fork springs my weight
fc shock spring my weight
previous owner did valves
previous owner put on wb full carbon exhaust (very loud)need to see if theres an insert to quiet things down, sounds like nascar when i start it.
previous owner put in uni air filter
theres some scribing on the head so it might have some porting?
piston?
cam?
new radiators
its pissin water for a couple secs at startup out the pisser hole
kn oil filter
two oil changes so far oil comming out still not great ,ive only rode
it up and down the road a couple times.
sorry for the long list ,it was kinda for me to see what i spent , i was kinda dreading adding it up.
my wife has no idea
tons of chemicals,cleaners,steel wool,scotch pads etc
tools to do the forks etc
and surly alot of things i cant remember
On the list to do?????????? probably a dynaring ,but i need to get some seat time to decide
Edited by fgrote
Change the WP seal and drill the hole in the impeller. Takes all of 10 minutes. Great looking bike!
Joe
i can't wait to post my bike up for you guys it looks so sick.. i'm waiting on a call right now for my rims and then they can be made and shipped to me.
thanks about the info on the pump , i had just read a thread , about the hole , i will do that , you can't see the other side of the bike in the pic ,but the shroud isnt on that side yet , i lost a aluminum spacer, need that , so i'll add the seal to the order , along with a missing mud flap, and a couple other tiny things.
the other thing is i hammered it down the road , and once it hit full throttle for a few secs, it started stumbling , its got a 180 main , i bought a 165 as recomended , but i'd like to step down a little at a time its not like you can do a simple plug chop on these things on the side of the road, is everyones opinion it will end up at 165?
Nice looking bike...who'd you have to kill to get it for $1900?
heck ,the guy was twiting my arm to take it, makes me a little nervous about the motor,for sure its going to need a seal in the pump ,or worst a shaft .
everything i changed above was either worn out ,bent broke or scratched to hell ,or past dirty i only splurged on a couple small things, i figured i could have spent more on a bike or take this one and put what i wanted on it ,and it would be new parts. I can't bring myself to add up what i spent in parts yet.
Im going to roll the dice ,ride it this summer , then tear it down , and hopfully only put a piston in it .
Im not that lucky though.
i bought a closeout jd kit yesterday , it was clearence price , and has main jets 170-195 so it was cheaper then,buying jets sepratly ,i already had a 165 and i ended up getting the two needles.
anyone need a blue needle?
Great looking bike. Sounds like the way mine is starting off, It's a bit of a pile 04, but with time,money and elbow grease ( right now I only have 2 of those components) it will be a good bike. I thought the same.. Buy a better bike or build this one the way I want..
Joe
What is this about and what year bike????
Before 2006, Honda's impeller on the 450 had one hole; the threaded one in the center that attached it to the impeller shaft. the issue, (some have had it, some haven't) was that as the cooling system ran, coolant would drip out of the weep port on the bottom of the pump housing. This was due to cavity pressure building up in the impeller housing, pushing past the water pump seal.
By drilling a .125 (1/8") between 2 of the fins, halfway in from the outer edge on the face of the impeller, this reduces the pressure built up in the housing by equalizing it in front of and behind the impeller; effectively taking pressure of the outer/water pump seal. It is very easy to do. It doesn't reduce coolant pump ability, and doesn't throw the impeller off balance. You could just as easily buy the impeller for an '06 CRF, but if you have a 1/8" drill bit, and a half-hour, it's free!
