KTM 350 sx-f Engine Bearing Recall
Basic information:
Problems with bearing 0625204280, which was installed in 350 SX-F engines up to serial number 1-772*05994*, can lead to bearing failure or even to extensive engine damage.
For this reason, KTM decided to promote exchanging of the bearing in the markets with another bearing that
meets higher bearing material quality standards. The new bearing 0625160040, together with the required washers, gaskets and restrictor, is contained in the main shaft bearing conversion kit 772 33 099 100.
Please contact your 350 SX-F customers to offer them the bearing exchange with the new conversion
kit. The bearing should be exchanged as early as possible to help avoid the risk of extensive and costly
engine damage. The conversion is reimbursed by KTM when a TI warranty application is submitted with the repair time
T3900233970 (245 minutes) and the material costs for the main shaft bearing conversion kit 772 33 099 100.
Source: http://www.e-dirt.co.za/forumnew/forum_posts.asp?TID=35755&title=ktm-350-recall
I checked with my dealer. It is true. Anybody that has one should call their dealer with the last 6 digits of their VIN.
This topic is now closed to further replies.
