transmission jumps out of 5th, 96 RM250
I've got a transmission issuw with my 96 RM250. In 5th gear it will frequently let go into false neutral, or go back to 4th. This usually only happens when I give it a lot of gas. The transmission doesn't do this in any other gear. Any ideas as to what could be causing this? Unfortunately it looks a a transmission rebuild may be in the near future.
Thanks in advance
Thanks in advance
I think it could be the shift cam stopper, I would open it up and see what is going on.
I believe I can get to that through the side case, I'll check that out first thing.
Hi.
I have the same problem with the same moto. Did you find what was the problem? Was the shift shaft stopper?
Thanks for your help.
Most of the time it is a worn or bent shift fork
