set up help
My boy has a klx140l we had the suspension professionally done, it has kx85 front forks and rear shock. We ride mostly hare scrambles, when he is on the long bumpy straight aways the rear tire doesnt seem to want to stay hooked up, it washes out, does the same when cornering, but not as bad. i was wondering if anybody had any suggestions
thanks,
joe
what pressures? sag set correct, tyre worn out?
pressure is good, sag was set by fcr suspension, tire is brand new. talked to my suspension guy he said it is the rebound or the spring needs to be one size smaller. will try the rebound.
