Frame rust question
Getting a little rust on the frame where the kickstand is, can anyone recommend a good fix for this? I know there is a spray paint that matches the frame color closely, but I'm concerned with stopping the rust. Anyone else get where on that part of the frame? (could be from boots?)
You could use some navel jelly and remove it but you'll have to repaint the affected area. There's a product I stock for the fisherman called OSPHO it's a phosphoric acid solution that converts rust, prevents and treats bare metals too. Works great for problem areas that need treatment often.
