broken nut on cr 125
when changing my tire i had a screw brake.its the screw that you loosen to adjust your chain and where the tire sits it broke off very easily and i am scared of it breaking again i need to figure out the best way to safely get the screw out was just wondering if anyone knows a way to get it out or repair:banghead:
Search Google for "screw extractor". You get them as a set or individually from home improvement and hardware stores. While they are great aids, they don't make the job easy. It will still require someone with some experience (probably) depending on the situation, ESPECIALLY dealing with aluminum.
