03 cr250 rad valve owners?
Haven't installed mine yet, I notice it does not come with a " valve stuffer" block like the oem cage does, but uses a gasket to cover the open cavity between the stock carb insulator outlet and the rad vlv. Won't this gasket flutter around in there a bit without anything to seat up against other than the edges of the bolt pattern.
