2002 RM125 reed cage gasket
Does this bike have a reed cage gasket? Microfiche isnt showing one.
The OEM does not use a gasket.
How does it seal? Should I use RTV sealant?
Thanks
There is an o-ring, but I used some RTV just to be sure. Do not put a lot though.
Don't use RTV, it will make a big mess and come off.
O-ring is a better seal, clean the surfaces with 'contact-cleaner' and put it together.
It did not have RTV from the beginning, it don't need it.
The only sealant I would use is something like Yamahabond 4 or 1104 or the equivalent.
The 'vehicle' RTV stuff is junk on bikes.
Thanks guys :smirk:
