carb help
Ok I just installed a mikuni carb on my sons Yamaha 125. Bike starts right up idle nice. Here's the issue. If I pull slowly on the throttle its ok but if I pull quick it bogs out. I have tried all clip setting no change. Any advice would be wonderful. Maybe its happend to you and this could be a quick fix. Rejet?????
Most will 'bog out' when revved on the stand. Ride it & see how it goes....
Its a 2001 TTR-125 from idel to a quick pull on the throttle it cuts out.
are you sure you have the right jet??? I had a ktm 380 and changed the clip settings from 0 to max and had the same issues. Ended up being that my jet was a 165 and needed to be a 142 (bought the bike used in a different state).
If you know anything about carbs, I would check with guys that run that same bike at your elevation and make sure you have the correct jetting.
Good luck!
The main jet is a 102.5 and pilot is a 17.5 I'm so frustated I mean it can't be that hard to figure out. And I don't want to take it to the dealer.I'm in Sacramento
