Braking into a corner
When I brake really hard using the front brake going into a corner the suspension becomes unsettled when I let off the front brake to transition to turning what do I I need to do to smooth out this transition?
ease off the brakes later so that cornering load keeps the suspension compressed. When you let off before leaning in the front rises, then dips again when you lean in. You want to make that seamless.
Its actually called "trail braking" where you stay on the brakes lightly until you're past the apex and able to use the throttle full.
Using the rear brake on entry will also help settle the bike as well.
