Nut Size ??
Tearing down Son's 92 RM 125.What size is the Main large nut holding the Clutch basket on ? And is it reverse thread ?
Thanks-Prostreetray.
I just pulled a basket on a rm-250.......it is a 30mm socket....and regular threads.
The water pump impeller was backward thread though.
The basket on mine , has a washer behind the nut ...that is soft....and lets you bend the ears up to keep the nut from spinning......thusly the 30mm nut does not need to be tightened up very much.
xxx
Thanks alot for the info
prostreetray
on my rm250 from 91 i used 27socket
but i'm from europe, don't know if that's the same thing
ow yeah, on the 92 rm the water impeller isn't bolted on :smirk:
it's stuck on a little axle wich is fastened with a circlips which is connected with the powervalve governor
Thanks for replying.I get the clutch basket nut,although im wondering why the washer behind the nut does not have the the tabs that bend down on the two sides of the nut.???
Now --On to the Water Pump/impeller-How do i remove it ?
Any help would be appreciated Thanks-Prostreetray.
Here is a couple of Pics so far.I pick this RM up for $150 no joke -was going to part-for the Front end and aftermarket shock,but,it's too complete to end it's life.Again Thanks
gotta take off the whole clutch side carter
you'll see a verry little sprocket on the backside of the impeller with a ring/circlips on it, release that and the impeller comes out.
and it's normal the washer hasn't got any grooves, it's just a very soft washer, you can bend it very easily
10-4 Thanks will get in it tonight and post what I find
Ray.
Started out with the Coor's light--favorite dog --and the wrong size socket for the clutch basket-- The 30mm too big.Any clues ? Thanks-Ray
If 30 is too big it will be a 27.
Typical clutch basket and primary gear sizes are either 27 or 32mm.
Thanks 4 the reply-I will post pic's as it comes apart-Everything looks good so far,but look at the Pic of the drain-plug---J B Weld at it's best!
My 2001 RM250 clutch basket is held on with a 30mm nut.
