weird thumping noise-diagnosis?
While riding Long Lake single track in Mich. Friday morning, I started noticing what sounded/felt like the engine was moving in the frame. I would feel/hear a thump when going over woops.
Last night I removed the rear swing arm thinking that the link bearing were shot - they are fine. The only thing I found was a missing nut on the link holding the bottom of the shock. Check some of the engine mount bolts and they are tight. I'll keep checking them and starting to wonder if there is free play between the engine rear mount and the swingarm pivot bolt.
since I'm running out of ideas... can someone suggest another cause?
I'll be riding tonight on a borrowed x model in the meantime.
Thanks
Stephen
No it's a hard clucking sound. I was told to check the lower eyelet of the shock. Any other suggestions?
Got the swingarm back in after loosening the motor mt bolts and tweaking the rear of the motor left. Once we got everything back, noticed 1/16-1/8" play in the frame top shock braket. Also observed a missing exhaust bolt. Replacing fasterners and using blue locktite!
We'll have to drill the frame and sleeve it.
Edited by SVR6
update
