KLx250 carb needle swap?
Can I use the needle from the keihin CVK34 N1TC klx300 on the CVK32? (N1SA)
The needle jet is the same part number, but the needles are different
I live in Thailand and the cvk32 needle is not available here.
What effect is the other needle likely to have?
.I have a klx250 1996 d4 (probably)
The other main difference between these carbs are the main and pilot jet sizes. Would I need to swap these also?
ALSO does the washer/s go on top or under the circlip?
Edited by alricalric
addition
