Splined washer??
Hopefully this isn't a dumb question. I had my motor rebuilt, but was waiting on a new clutch basket so that didn't go in at the shop. I went to put it in tonight and installed the splined washer behind the basket as indicated in the shop manual. The washer goes beyond the splined area of the shaft and falls between the basket and the inner hub. It does not engage the splines. I have read and reread the manual several times, and even gone on line to see an exploded view of the clutch assembly to see if I am missing something. I am assuming the splined washer is supposed to engage the splines when fully assembled, correct? I can't see any parts I'm missing, and I don't remember having to work the washer over the splines on the way out. So does anyone have some insight? I would really like to be riding by this weekend if possible.
Year?
06, thanks for answering. I figured you would be one that would since you had that Dyna Ring in and out so much! I got an answer from one of the members of our club who owns Kawis. Turns out that, no, it doesn't engage the splines. :smirk: One less thing to deal with...
06, thanks for answering. I figured you would be one that would since you had that Dyna Ring in and out so much! I got an answer from one of the members of our club who owns Kawis. Turns out that, no, it doesn't engage the splines. :ride: One less thing to deal with...
:lol:
  • Similar Content
    • By tanner_shany24
      Hey guys, I have a 2012 KX450f and it is giving me major issues. I will give you a run down of the history of it. I bought this bike a few months ago and have only ridden it really once, yes once! When I bought it everything seemed to check out, it ran fine, started fine, sounded fine, so I bought it. Took it out to ride and the first hill I hit it got really hot and overheated like a SOB and spewed coolant everywhere. I thought to my self maybe it was because we were riding trails slow before so maybe when I actually got on it it got too hot. After that though, it began to overheat every 3 minutes no  matter what, I would ride it for 3 minutes, and have to stop to let it cool down because I was scared I was going to melt the top end. Got home and started inspecting, found out that oil and coolant was mixing both where the oil is supposed to be and where the coolant is supposed to be. After some research I found that the 2012 450 had head gasket issues. Assuming that was the issue, I took the head off and got it resurfaced (it was actually decently warped) and put new gaskets in everything top end related. Piston and cylinder looked brand new by the way. So I put it back together, started it up, and it instantly started spewing coolant and oil mixed out of the crank case breather hose. Like literally as soon as i started it and it would make a puddle on the ground in 10-15 seconds. I'm at a loss here, brand new coolant and brand new oil, brand new head gasket and resurfaced head, and it instantly started doing the same thing again? What could it be? Is it worth my time or do I part the bike out? I have put way too much time into this bike to want to tear back into it again unless it is something cheap to fix, if not I am going to post it on craigslist and let someone else deal with it. Overall this whole experience makes me want to go back to a 250T! XD
    • By Sam Mclean
      Hi new to this site.
      Ive just bought a cheap kx450f with what i thought would be a minor issue.
      I was told it was only running with the choke on and i thought easy fix, just a blocked jet. So i pulled it apart as must of the person before me and i find a broken soround thing that the plastic case sits on around the pilot jet. So i appoxy that back on unblock the jets and clean it all out, put it back together and now i try starting it for the first time and see the fuel dripping as it was when i bought it. When i look closer i see it is seeping from what looks like a crack in the float bowl. Ahhh
      So my problem is. Looking for a cheap carby might solve all my problems or just a float bowl at worse case. Now i can find many kx450f being wrecked nearby so im wondering are most 450 carbys the same? Will one of a yz450f work?
      Can someone please help
    • By Sam Mclean
    • By BadcaseofTB
      I missed tracking where this little top hat came out of in my 2011 kx450f. Was thinking clutch or right side engine cover. Any help would be appreciated I can’t seem to find it in the manual.
