New FCR Setup
When i recieve my NEW FCR from the TT store is there anything i need to do to it before installation? Anything that needs to be set, checked or adjusted?
Besides the removal on the PAJ, i know about that one.
Cheers
One of the following: Oring mod/wire linkage/stiffer AP cam spring
Install a extended uel screw- Brass or stainless, not alloy!
Follow the directions carefully, Read the FAQ about the install in the DRZ forum
Should I use the needle that comes with it or swap to an EMN?
cheers
Install the EMN as per the instructions. There is a good write up with pictures in the FAQs in the DRZ forum.
