'06 250SX-F cam chain tensioner seal
Can I replace the copper cam chain tensioner seal without having to re-time the motor? Are there any precautions I should take before replacing the seal? My buddy told me to get the piston at TDC before replacing the seal; is that necessary, or can I just remove the cover and replace the seal? Any advice from people who have done this before on this specific motor? It has a 280cc big bore kit, too, if this somehow matters.
Thank you! :smirk:
Edited by BP88
Another thing, the oil level is at the middle of the sight glass when not running/cold. On my bike the oil level should be near the bottom of the sight glass when not running/cold. Is it possible that it's just overfilled and this blew the gasket? I know this is a common issue when the oil level is too high in some bikes. My buddy bought the bike this way and didn't really know much about 4-strokes.
You must have the marks on the cams facing each other before you remove the tensioner.
Collapse the tensioner when you refit it, then release it with a screwdriver on the tensioner blade from above or a allen key pushing through the small hole in the tensioner cap if yours has one.
Thanks, but can I replace the copper seal without having to remove the tensioner itself? I'd like to avoid that if possible. That's what I'm trying to figure out.
Thanks again.
No you have to remove it. Honestly... I have doen this on my bike about 50 times. Take of the cam cover. Line up the marks to face each other. Then turn out the bolt beneath the waterpump, remove the copper washer and lock the crank. Then you can take out the tensioner. There is also a step by step procedure to replace the tensioner. You cant just take it out and replace it.
Edited by Boerklong
What you can do is take out the sparkplug to reduce compresion. Then remove the bolt beneath the waterpump and shine in there with a torch. Slowly push the kickstart down till you see n gap in the crank. Remove the washer from the bolt you have taken out and screw back the bolt to lock the crank. Then you can remove the tensioner, but... To re install the tensioner you HAVE to remove the cam cover. I have learnt the hard way and it really takes only 20minuts to do.
no need to lock the crank to do this. As long as the chain doesnt move on the gears inside it doesnt matter. Lining up the marks is the same, no need.
The washer does come off if you can get the tensioner out of the motor with it in the frame. I fixed mine by heating it with a torch and then surface sanding it on both sides. This got it soft and flat again. Took 15 min and no trip to the parts store.
  • Similar Content
    • By Urbanpoacher
      Hello everyone, I am new to the page and to the world of ktm. I recently purchased a used 2008 ktm xcfw with a 300 big bore kit, not sure who made or installed the kit. I am looking to see if there is any way to buy a new carb that is set up for this bike with the 300 BB. Any help would be great. The fuel inlet is leaking and there are a ton of stripped screws so I’m thinking getting a new carb might be the best way to go but i don’t really have the skill or knowledge to tune and jet a stock one myself. Thank you!
    • By christophe19912
      i am currently checking valve clearance on 2013 sxf 250 with 70 hrs. bike was bought new and never been apart(as far as i know). when setting TDC the notch on the crank when it is aligned to the whole, has the cam gear marks intake totally up and exhaust totally down. are these the wrong marks to look at or am i missing something. bike does run just a little difficult to start.
    • By gyodock
      2016 KTM 350xc-f - Olins Fork Cartridge Inserts, FMF 4.1 RCT Muffler, Pro Circuit Linkage Arm, Torc1 Reaction Shift and Rear Brake Lever, P3 Carbon Pipe Guard, Acerbis Skid Guard, Mobie Linkage Guard, Acerbis Swing-arm Guards, RYD Crew Aluminum Handguards, Sicass Racing Tail Light Kit with Flush Mount LED Rear Turn Signals, Sicass Racing Handguards with Built-in LED Turn Signals, Rental Sprockets, Trail-Tech Stator Upgrade, ktmandhusky.com Fuel Rail and Anti-vibration Bar Ends, Guts Seat Cover, USB Charging Port, Misc Anodized Orange Aluminum Bling. My wife is getting jealous of the attention I am giving my bike!
    • By Dandeliongardens
      Hey all. I’m a newbie here so let me know if  I’m in the wrong place.
      I’ll get straight down to it. I’m in the market for a new bike and have been thinking about what’s going to be best for me for a long time. Until recently I finally came to the conclusion that a new YZ250FX is my best option. My last bike was 2015 Yz250f which I loved.
      Now just yesterday I saw a local dealer advertise left over 17’ FX350’s for almost the same price as the YZ. What appeals to me about the Husky is that extra grunt. What doesn’t appeal to me is the suspension and handling and the reliability of the machine. Now I’ve never owned a KTM or Husky so I am basing those two factors on word of mouth only. Like I said, I loved my Yz250f and felt very at home on it, it has probably been the best bike I’ve owned to date. Yamaha reliability is also second to none which adds to my peace of mind on purchasing the YZ. One thing I wish it had was more power though. Obviously it’s only a 250f so you can’t expect it to go like a 450 (not really interested in 450s).
      I ride mostly trails and the occasional day at the mx track. The trails I ride are gravel based, loose, rocky, single trail, and also wide, fast, flowing, sand trails which is where I think my yz250f really shined, and where I had the most fun. I’m only a small rider at 145lbs which is why I’ve steered away from 450s.
      I’ve read a few forums and others have said the ktm and Husky 350s are unbeatable on the trail which is why I am in this dilemma.
      So basically what I’m trying to decide on is if that extra power is worth compromising for the YZ suspension, handling and usability. Feel free to make any other suggestions, including other bikes as I was also considering the YZ250X 2T.
      Thanks guys
    • By element9
      The story begins with simple installation procedure of a BIG BORE kit that we ordered from USA . The manufacturer (CYLINDER WORKS) and the dealer send us the correct kit and so far so good ! .
      The bike is a KTM 250 sx-f ,2011 model and bellow there are some photos for you, just to see how careful I am throughout the process .
      .. .. .. .. I change the valve seals and the exhaust titanium valves and springs with the PROX steel kit and make a little polishing on the intake and exhaust
      Put the cylinder-piston on and always with guidance from workshop manual and correct clamps...
      AND READY
      Until now we where happy !!! We start the engine ,and everything seems to be ok!
      Began to make the first ride and…… DISASTER !!!
      The engine start bleeding OIL from the hose-tube !!!!!!!!! I thought its normal if it is one-two drops but unfortunately didn’t STOP .
      We did one more ride to see what happens and still BLEEDING. Back to the WORKSHOP.
      DO YOU HAVE ANY SUGGESTIONS OF WHAT TO CHECK OR DO ???
