08 kx250f motor mount on frame cracked?!?!?
So I was getting ready to drain the oil in my bike and when I went to take the skid plate off I noticed my left motor mount was cracked half of the way threw!:smirk: I was wondering if I can weld it and be fine or do I need a new frame? I also am aware that you need a aluminum welder for this as well. The crack looks like it is Going straight threw the bolt hole and that's what scared me about if it was even okay to weld there.
I will post pictures tomorrow of what I am working with. Any advice would be helpful or if you had this same problem how did you fix it.
Thanks nick
i would personally not even attempt to weld it . i mean it could be a temporary fix but the frame is built for stability , and that could cause weakness leading to more damage or injury . just my 2 cents
heres the picture of it..
id probably take it to a shop and see what they say . but if it was me personally id buy a new frame , no one can tell you how much that can weaken the frame .
  • Similar Content
    • By drewkuze
      I recently bought a 2012 kx250f. The guy I bought it from said he never adjusted the valves, but the previous owner bought a new engine in 2014. The bike is burning oil (I haven’t had a chance to do an oil change yet so idk how much) but it burns on startup, and when the bike is revved high quickly. It isn’t hard to start, every time I’ve started it it only takes 1 kick. I’ve heard it could be the valve guides, seats, or the piston rings. Any suggestions on what it most likely is?
    • By Toms.abpg
      Just bought this bike and the pop on decel is horrible, looks like I’m gunna have to try a Tokyo mods remap. Anyone had success with this ?
    • By _Cloudy_
      Hi, I have just bought a kx250f, 2013 with a freshly rebuilt 2016 motor in it, this is my first time on these forums, anyways, I have also bought a lowering link to drop it 4 inches on the arse, I was wondering if anyone knows how much I should drop the forks?
      I havent put the lowering link on yet.
      Thanks.
    • By Zach Miner
      Recently had issues with the original fcr carburator that was installed in my 2009 kx250f, tried jetting multiple time and different gas and the bike would only run with the choke ziptied out. Do I went ahead and purchased the lectron gen 2 4 stroke carburator kit, was kinda expensive and I was kind sceptical but after my first ride all I got to say is wow. The only adjustment I have done it set the idle, the bike runs amazing and feels as if there is more power than before. The kit came with a new throttle tube assembly and a g2 throttle tube with adjustable cams for throttle response. I highly recommend if you have a carburator on your four stroke and don't want to get a new dirtbike that is fuel injection then go the route of throwing out that junk fcr carburator and get a lectron gen 2 carburator for your old 4 stroke
    • By DirtbikeDon
      I own a 2012 Kx250F that I would like to make street legal if possible and I recently saw Rocky mountain I believe sells these battery packs that sit in the airbox for bikes without batteries that looks too good to be true and a headlight and turn signals like a conversion kit basically and I was curious as if anyone has had luck with those or if there junk it would be nice to make my bike street legal for short trips or just have lights for trail riding with friends that already do if possible any tips on converting it?
