Rebuilt 2006 KX450f piston is very tight
When I kick the bike over the piston feels way to tight in the jug. I dont know if I should try starting it like this if it will cause damage or not. Its a new wiseco piston with a new jug.
Did you Mic the piston to see how big it was.You have to check clearances on cylinder and piton.
I thought Wiseco only make two sized (bore) pistons. Std and oversized. So you check the part number. With a std piston and a healthy nikasil bore, then it has to be some other problem like the rings.
Maybe not the rings. Did you torque down the cam caps to the right spec? If they are too tight it will give you a Binding feel when you kick it
I did tourqe everything to spec and the piston I bought from a local machine shop that worked on the jug for me.
you're going to have to pull it and check the end gap. I would almost guarantee that will be your problem if you didn't check it before assembly. Did the bottom end rotate freely before you installed the piston?
