Reshimmed Valves - Higher compression?
On my E kicker I recently redid the valve clearances.
The initial clearances were:
In: <0.05 & <0.05
Ex: 0.15 & 0.20
After replacing the shims they're now at
In: 0.12 & 0.10
Ex: 0.35 & 0.35
My digital caliper mustn't have been accurate enough when I meaured the original exhaust shims (couldn't see any numbers stamped on them) and so the exhaust valve clearances are 0.1mm over the OEM optimum range (which is 0.2-0.3)
My problem is the bike now has higher compression and is now a lot harder to kickstart when it's warm, it looks like I might have to reinstall my hot start lever.
If I redo the clearances and bring the exhaust clearances down 0.25 will this reduce the compression?
Before did the reshim my bike was very easy to kick over.
The only way you would reduce compression is if a valve is being held open (no clearance) NOT good, when I had kicker thumpers I played with the idle mixture and idle speed to get the best starting I could.
I have seemed to work out that if I treat it like an old XR600 :ride: and click it to TDC before I kick it over, it usually starts first time.
It's just strange the amount of kickback I have now compared to before the reshim. I think I'll redo the clearances closer to OEM spec next week when I have some spare time.
I also have a kicker -not E- . Suzuki put a hot start button on these bikes for a reason. It works. My bike, when she gets good and hot, is damn hard to kick over without the hot start, and I have a virtually brand new top end (new valves, springs, seals, etc..) I use the hot start so much I invested in a handlebar mount hot start from yoshimura. Zip Ty also offers one for the DRZ. much better in that I don't have to reach down near the carb to mess with it.
I can't reinstall my standard button in the original place as I have my Stebel airhorn there. $50 is expensive for the handlebar switch (especially since it'll be $70-80 after postage from USA) so I might look at relocating my standard button to the handebars instead. It looks pretty straightforward, all it will need is a bracket and a filter for the inlet hose.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
