Master cylinder shot?
my 2009 150 hour KTM xcw 300 rear master cylinder doesn't hold pressure.
I can't see any leaks.
the rotor doesn't have a noticeable warp.
Pads good.
I just flushed and bleed the brakes both manually and with a hand pump vaccum bleeder.
The pedal still bottoms out.
Is the master cylinder shot?
Is this common on the KTM?
Check the o-ring/seal at the caliper
