'07 450 EXC-R Key Elimination
Looking to eliminate the keyed ignition on my '07 450 EXC. Anybody done this or know of a plug & play switch to replace the key? Any help appreciated. Thanks
On past KTM's I've had with keyed ignitions, when the key is in the "OFF" position it's simply completing a circuit that goes to ground, effectively bypassing the starting circuit. When you turn the key to the "ON" position, that ground is short circuited.
Easy solution to eliminate the key - find the wire that is the ground from the ignition and disconnect it.
sicass made me a bypass wire that used the same plug so no cutting of wires or micky mouse connections.
They would probably make some more.
