will a 19" rear fit a 2011 XC300w??
Wanted to pick up a spare set of rims to ultimately use as a spare set for DOT tires. Another member is parting out a 2008 450sxf. I believe it came with 19" Not sure what sprocket it has.
Will it fit my 2011 xc300w? Would I need spacer? Clearance issues?? Any thoughts?
Also .... any DOT tire suggestions. 20% road 80% trails
Yes it will fit. There should be no issues considering the 250 SX uses the same swingarm/frame and comes with a 19".
KTM wheels have all been the same for many years. My 09 SX is currently sporting an 18" rear from an 04 model. The hub is a different shape, but the axle, spacers, etc. are all a direct match.
A friend had an issue with his 2010 model EXC, the 19inch wheel scrubbed and rubbed the black plastic mudflap/swingarm guard to pieces.
your friend needs a longer chain! Doh the OD of an 18 and a 19 are the same, the tire has a shorter sidewall on the 19
