Clutch Fluid Bladder?
Just pulled the cover off of the clutch fluid reservoir to make sure there was still oil in there and the bladder inside is so stretched out I can't get it back into the reservoir. It's on an 07 300xc, anybody else ever have this happen? I check it periodically and have never had this problem before. It also looks like you can't buy just the bladder, you have to buy the cover and bladder together
Edited by bajaklx
mispelling
If it's just stretched into the reservoir, they normally just "fold" back into their normal shape. If it's seriously stretched out, possibly mushy, and swelling, would question contamination of the fluid. Brembo, right? Make sure only brake fluid, no oil based products, or any rubber in the system will get all out of shape.
