2004 CRF250r over heating
My CRF250R is overheating very quick. I need help solving this problem...I'm not a mechanic, but I'm not clueless...coolant is full, water pump appears to be working properly, oils are full also. This thing heat up in a matter of seconds...less than 30 seconds. I did notice that the hot start set that connects to the carb is broken...could that cause an overheating problem?
The coolant is full but it could be airlockedtake your radiator cover off and then start it. See if there is any bubbles or any movement
