Does Premix oil go Bad?
as long as the container was closed, then yes you can use the oil. I had the same exact oil ( guy gave it to me when i bought the bike ) and almost 2 years later, used it and no problems
2 stroke oil is solvent based and if kept closed its fine . Left open will evaporate,Still works however wont burn correctly.
It's not milk. It's fine - forever.
Did you know that the pre-mix found in King Tut's tomb was still good? This is a little known fact because most claims talk about the wheat seed that still germinated.
Yes even then, 2-strokes were discriminated against.
Edited by RayIn
