cant find an answer
hi
2010 rmz 450
im hearing that with a stock bike, completely stock, that there are two wires which you can alternate to change the ignition maping on the bike from leane and more power option?
is this true?
if so how and where?
thanks alot!
The 2010 RMZ 450 has 3 different fuel maps pre-programmed into the ECU. To switch over to one of those three you need to have the factory connectors that came with the bike. If you do not have them they can be ordered from your dealership.
so you need to get the connectors...they are not already located on the bike?
also do you know what the different mappings are?
thanks
