rim lock 19 use on 18??
can i reuse the rim lock from a cr500 19 inch rear on my new 18 inch rear>?:thumbsup:
It's the width of the rim that will determine the rim lock size you'll need, not its diameter. If both rims are the same width (for example, 2.15), then you can use it.
