Carby Problems - Mikuni TM40 - XR650R
Hey guys i have had my Mikuni TM40 on my BRP for quite a while now and it has been great, that is until today when i went about my normal ride and it started off great with me starting the bike and gearing up whilst waiting for it to warm up as usual until it randomly stalls and then i notice fuel pissing out?
I start it up again and manage to get going somehow and then every time i came to a stop it wanted to stall and did several times. It seemed to have gotten better once it was warmer but on the trail several times it would be pissing fuel out at one time and not another when sitting or riding whether it was straight or leaning.
It still seemed to run ok but what could have caused this because the float level shouldn't just change by itself and it wouldn't be stuck would it?
Any ideas before i rip it off?
check the bowl, float valve and seat for debris
Just read your post, mine is doing a lot of the same. It continually pisses gas. When it first started doing it I got a lot of weird serging action while it pissed everywhere. I took the bottom of the carb off and and seemed fine, float seem right on. Didn't know about float valve. Did you clean that, if so did it help?
Mine is a 2000 XR650R, just bought it and was told it has been jetted and uncorked.
Pulled the float valve today and cleaned it, took care of pissing gas problem! Now I just gotta fine tune it.
Took mine apart today and had a look at everything and it all seemed ok, so put it back together and tried it, seemed ok, will have to test later during the week.
Hopefully its alright.
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
