03 rm250
Yes, the jetting is a nightmare, been wrestling with it since new. I had it pretty well figured out but perhaps now I'm looking at a new problem?
I ride woods and have all new lower-end, top-end and replated cylinder.
When cold she starts, but takes a ton of kicks when hot.
Inconsistent idle (slows down as it sits, then stalls.)
Idles real fast after coming out of real tight, technical woods.
When connecting trails with gravel and blacktop it runs fine when 0-1/2 throttle, falls on face up to 3/4 throttle, rips when on the main.
I'm running a JD Jetting kit per instructions (0-3000 ft)
All jets are clean, float height is correct.
V-Force reeds are tight and not chipped/frayed.
Silencer is freshly packed.
Stock plug w/ correct gap.
This inconsistent idle thing does not mix well with the Rekluse EXP clutch.
And man I kick forever when it's hot.
I'm guessing it's not a jetting issue since this just recently started.
Electrical? Any ideas where to look?
Powervalve is clean and working.
I'm either dumb, blind, or both. This going-on-53-year-old needs his reading glasses more often.... Carbon fiber reeds had the tinyest bit of fraying at the corners.:smirk:
Have you changed to the #7 slide?
Key to jetting an 03.
My 03 is jetted as follows for 1500- 4000' with V force reeds and a Gnarly pipe, PC 304 silencer.
42 pilot
stock needle 2nd clip
#7 slide
168 main
2/3 91 pump premium to 1/3 Avgas with 33:1 premix
Runs crisp and strong all around and starts first to second kick hot or cold. No spooge as long as I'm not running a spark arrestor (PC 296)
I ride/ race alot of woods with a little MX thrown in.
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
