Head gasket?
Ok i have a 2007 that keeps using water. It is coming out the overflow and i have already installed a new 1.6 pressure cap and that did not fix. it is also blowing oil out the vent hose. also while running if you take out the oil fill cap it will blow oil everywhere.
ok, the oil problem is fixed. i had too much oil in the case. but still building pressure in the radiator and forcing water out overflow.
when my head gasket was bad (due to an improperly torqued head, it lost water out the overflow and overheated.
Gasket was was clearly bad upon inspection.
