03 rm125 clutch
When the bike is in gear and i pull the clutch in should it move freely or should it resist a little bit? Its my first bike and when i pull in the clutch it doesnt move freely like my sports bike. Is this normal for a mx bike??
Like how ???? with the engine off ....and you put it in gear and push with the clutch in ???
Your bike is 8 years old............and has a quick access cover to the clutch pack.
You can inspect the basket for notching......the plates for warpage , burned smell , thickness. Put bike over on left side....and you do not have to drain oil.
I can't push any of my bikes around very easily in gear , with clutch pulled in .....
Thanks for the reply i just wanted to make sure the clutch was not adjusted right or something.
